Ok im going to make a rear bar to remove the Hicas rack and need to find out what can be removed.
I was going to remove all the lines up to the firewall and either bolck off eack line or loop them together but i was told this can couse problems, what have other people done to completly remove the hicas stuff not just trick it into not working.
https://www.sau.com.au/forums/topic/20572-hicas-removal/
Clint, sydneykid went into a bit of detail on how to do this on a previous thread (or 2). think he mentioned swapping the R32 pump for a R33 one (as R33 hicas is electric) and removed just about every thing else except for the lines under the plenum as he used them for fuel lines.
Perhaps a pm or a search?
https://www.sau.com.au/forums/topic/20572-hicas-removal/#findComment-431647
I read that in one thread steve, but im after the easy way if there is one, changing power steer pump is a job for when i pull the engine out, i am just trying to find if anyone has had success with leaving the pump in place and modifying other bits.
https://www.sau.com.au/forums/topic/20572-hicas-removal/#findComment-432798
