hi guys was driving my car 2day then then all of a sudden its lost alot of power and sounded like a wrx. I have a 32 with a rb26, I took it to a mechanic to have a look at it, Had about 10 grand spent on the motor 6 months ago so I was very worried something had happend, they guy did a compression test and everything seems to be fine 150psi across all 6 cylinders and plugs seem to look ok aswell? wot else could cause a cylinder to drop out? its cylinder 1. I have just put new splitfire coils in it aswell so I can eliminate that and It did have new plugs put it it last oil change
Edited by boosted_32
https://www.sau.com.au/forums/topic/205885-wot-causes-a-cylinder-to-drop/
could be an injector, coil, or the ignitor pack, the wiring to the ignitor pack, the wiring from the ignitor to the coil, the wiring to the injector, it even could be the cas.
start with, pulling the coil out of cylinder 1 and swapped it for say cylinder 2, if the problem moves to cylinder 2 then its the coil. if it stays on cylinder 1 then its something else.
then i'd checked the injector is getting its pulse, is it squirting fuel. if it is its probably the ignitor or cylinder 1's ignition wiring. if not then id check the cas out.
hey mate found the problem but dont know where to start to fix it, we took the plug of the injector for cylinder one and put a test light on it and you can see the light flashing on and off as the injector is pulsing but then all of a sudden it stops for a bit then comes back on and keeps doing it, so every time it looses power I drop cylinder 1???
when you say your watching the injector test light flash, then stop for abit, are you just watching this while your cranking the engine, or when the engine is running?
what ecu are you running?
and did you check the condition of the wires and plug for that injector?
yeh had the engine running and took off the injector plug to test it with a test light and the light pulses as its ment to but then cuts out for say 30 sec or a couple of mins then comes back on......keeps doin this. Im running an emanage piggy back
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
