hey all.
mates got a 4 door r33 gtst which started stalling yesterday.. since he put on a dump pipe.. it only stalls when at idle, drives the same, a bit extra power.
what happens is that it stalls after 10-30 secs of idling... otherwise it drives fine.
mods:
FMIC
Full exh
pod filter
stock boost(7~psi)
wasted spark setup
HKS bov(working fine before)
weve tried to unplug the aac valve, and that doesnt make a diff.. the lambda sensor is unplugged, it doesnt make a diff even if plugged in(as its only for fuel economy anyway)
any ideas? weve tried resetting th ecu. all the plugs seem to be in place and nothing loose.
Help??
https://www.sau.com.au/forums/topic/205909-r33-stalling/
I don't care if the BOV was working before, I bet its causing the problem.
Take the Piece of junk off and put a plumb back on, or put up with the stalling.
Do a search for stalling and you'll find plenty of threads.
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3643708
I say it is the bov I had that problem when I got mine installed. Basically mine would stall every now and then but xspeed sort of fixed the problem by adjusting the the car to idle at about 900-1000 rpm instead of 600 rpm. Did not work 100% but heaps better. The only way to fix it 100% is get one that is plumbed into the car.
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3644202
why would the bov cause the car to stall AFTER it's been idling for 10-30 seconds?
I'm a hater of bovs as much as the next guy but it doesn't make sense.
When it stalls, is it sudden?
as in, does it idle along perfectly then completely cuts out, or do the revs drop a little and car starts to splutter, then stall?
Is the car auto or manual?
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3644556
thanks for the replies guys! :blush:
well.. say ur idling in the carpark with the keys in the ignition.. after 10-30 secs it will struggle ALL of a sudden.. seems like the spark is there, the fuel is there but it stalls. seems like a sensor or something is all of a sudden...
i will try putting on my stock bov tonight if i have time.
i also have my suspicion on the bov but then im not 100% on it.
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3644962
I'm going to suggest the AFM.
my 200sx did this on occasions.
the cable to the AFM on my car was dodgy and would sometimes cause a temporary bad reading. enough to cause it to drop revs, then back up and sometimes just struggle for 2 seconds then stall.
see if you can force it to happen.
pop the bonnet.
start the car.
then move your afm cable around.
or even move the afm around (if you have a pod filter instead of stock airbox).
in the DIY section of these forums, do a search for "AFM+SOLDER" to find the thread on how to repair a faulty AFM.
also, if you haven't already done so, take the AFM off and spray the inside with electric contact cleaner.
this will clean off any oily shit and dirt that might be there causing the problems.
spray on and it's clean and dry within 20 seconds.
The soldering is also pretty easy..
have a search/read
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3645099
yeh i had my suspiscion on the afm as well, however it runs fine so that kinda rules it out, but ill have a play around either tonight or tmorw.
i sent him to my tuner today so hopefully he can give him some tips.
would a clogged up aac valve do this? i dont think so, as the aac valve is only good for when cold right?
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3645126
idle is BOV - its probably got a really small fluctuation that is causwe the bov to open and shut a little bit. Then after a while he BOV opens and shuts a little bit more and more each time, then eventually after 20 seconds, its opening too much on idle and you start to notice how much your piece of shit BOV is making the car run like a dog.
Take it off and I bet the problem is fixed.
Or prove me wrong, and put a piece of coke can inbetween it and block it off completely and tell me if it stops idling bad.
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3645350
alright so my tuner just had a look at it.. reckns its the aac valve..
thing is now that it idles at 2000rpm and doesnt stall as often.. maybe say 2/5 times only. so were gna quickly clean out the aac tonight, if that doesnt fix it ill chuck on my stock bov. :happy:
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3645447
lol and once you have put the stock bov back on might want to lower the idle back to normal. 2k is just silly
https://www.sau.com.au/forums/topic/205909-r33-stalling/#findComment-3645874
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
