I'm not a F#*kwit mate i know where offsets are
usually printed and there not there....
As for these wheels fitting perfectly on both those
toyotas and skylines...... They do cos i'v had them on both!
Edited by JDMS15
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3650307
Geez buddy calm down.
Well, it doesn't help when you say Toyotas. How F***ing open is that.
What skyline aswell?
If there are missing details, you gota help with as much details you know from personal use.
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3650334
hey mate whereabouts are you?
Any pics of the gutter rash? i will be painting the centres black so thats no issue, but wouldnt mind seeing the damage you mentioned. Have you had them on a balancer to see they run straight? At a tyre joint? they could spin them for $20 for you and let you know if they are bent or not.
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3673632
Hay bud i'm in vic,
And as for the wheels runnin straight yeah there fine
they used to be our dyno rims at work,
As for the gutter rash it's fairly extensive but nothin
that can't be fixed for fairly cheap!
https://www.sau.com.au/forums/topic/206221-sold/#findComment-3696960
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
