hey guys, had my car for a few years, and another one before that so i wanna get into somthing new maby
details:
im in sutho shire
1997 black r33gts-t series 2 skyline-104000km, 5 months rego
fmic-just jap
full 3inch stainless steel exhaust, split dumpipe, hi flow cat...a mix of xforce, jjr and batmbl dumpy..
bosch 040 fuel pump
tomei adjustable exhaust cam gear
greedy pro fec b sii electronic boost controler in cabin, low 10psi, high 13psi
brass button "cushion" clutch holds up to 280rwkw
gtr v-spec diff
abs, airbags
18inch gt intergal ssr's, with 245s at the back, 235 up frount
apexi power fc and hand controller in cabin
a-piller gauges, boost and oil (greedy and autogage)
dark tints!
lowerd king springs 2inchs
apexi power intake pod filter
new gates heavy duty timing belt changed at 95000km ( did it when i got the exhaust cam gear in)
nismo clear blinkers
new frount brake pads ( bendex ultimates) stops great
trust gear knob
kenwood mp3 player
alarm
non turbo badges
sprayed red brake calipers
it did a service at unigroup, all fluids, sparkies, o2 sensor etc changed in aug 07, where it pulled 222rwkw before injectors and afm maxed out
so its sitting on a safe 213rwkw now, i brought this car dead stock so im not suprised why it has good power as its had an easy life
its parked undercover through the week at work, and no i dont park it at miranda
$14,700 without power fc and without boost controller
i will put the standard ecu in where i pulled 182rwkw at ricol
$16500 as is drive her awayyyy
pm me or leave a comment or call, dont leave comments if ur not happy with price etc no1 cares
mitch
0405 204 561
Edited by cerci
https://www.sau.com.au/forums/topic/206322-r33-s2-215rwkw-for-sale/
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
