  • Replies 52
Posted Images
I always thought that a remap ecu was the tight ars way and that a PFC was the best way to go? :)
+1
Too much ignition DVD boys :)
PFC is good, no doubt, but now its getting old and there are a lot better ECUs out there.
As for remaps being tight ass, it goes back to what i said before, all depends who tunes it and what software.
*edit* and 1 of the reasons its cheaper is because it takes way less to tune it because you already have base maps to work with where as PFC u have to do everything from scratch as far as i know....i wouldnt want a noob tuner to set everything up for me from scratch thats for sure :banana:
Edited by KISIN
If the pfc is old and out of date does this mean the pfc boost contrloer kit is out of date and i should be looking at a stand alone boost kit witch will have more technology?
I cant comment because i have never seen it or used it, but i would think that a boost controller is a boost controller...there cant be TOO MUCH difference. Just make sure it has a MAP sensor as it will hold boost better :)
Can i just also add that depending on what setup you are going, and really want a after market ECU, i think Haltech is the best bang for buck.
Has a lot of tuning options
Aussie product (therefore lots of support)
Plenty of supporting Hlatech products (map sensors, boost cntr. kits, dashboards etc etc)
Turbs 13 (spelling ?) on here with 32 GTR went from PFC to Haltech and he said he would never go back.
Haltech E11v2 is their top of the range ecu and its around 2G new.
Edited by KISIN
i got a dyno at willall 215kw @ 10psi on the stock turbo and before the rebuild, i dunno how it pulled that number? possibly lean afr's?
bish33 - come along to the dyno day at boostworx like cubes suggested, it should provide an answer to your question here.
A few things the pfc has over the stock ecu.
PFC 20x20 load/rpm map vs the stock ecu's 16x16 load/rpm.
For myself the PFC felt noticeably smoother some how at small throttle openings.
PFC - Well known for its excellent interpolation between load/rpm points. = better fuel economy
The PFC has a dash flash instead of just R&R where it drops back to a 'safe' map that may not be 'safe' under some circumstances.
How an rb30det making 268rwkw manages 450km's per 50litres of fuel daily driving 60km/h stuff with a good tune is a testament to how good the pfc actually is at interpolation and the ability to tune it finer than the stock ecu due to its greater 20x20 load/rpm map.
The PFC has never been a fully fledged ECU; hell even the microtech has more features standard. :laugh:
There's really little point comparing it to one when they are worth almost 2x the price.
For the usual streeter a PFC is nice on the pocket and returns excellent fuel economy with minimal dyno time.
IMO. :P
before what? ahaha
check this link. another s1 33 with over 200kw and no upgraded turbo!
http://www.skylinesaustralia.com/forums/Fs...R3-t206585.html
all the evidence points towards it being a true reading???
:cheers:
Bish33 this wouldn happen to be the yellow r33 getting around would it? I say this because i always see it in Victor Harbor an thats where your from on your location :( Love the colour of your car dude, Anys i have a black r33 with a few mods an i dont know if you remember but we were down anzac's an we both gave it a bit of squirt (to the speed limit of course) You cained the living shit outta me i have just over 210kw so maybe this dyno read out is true an you have a freak motor, But seriously take it to the dyno day to shut these guys up but f*k me if you run anything under well its going be abit embrassing, Peace out dude an catch up soon insane33.
Simon's rb25det made around 220rwkw on turbo tunes dyno as well. Sounds around the mark.
Yeah i remember that car quite well, So i would say bish33 alot of people are rather jealous of your 220kw with minamal mods, Look at all the other dick heads on here spending huge dollars an getting only 200 its a joke. Well done i say an f*k everyone else.... :(
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
