all turbo skylines come out with a viscus lsd. these can be reshimed to act like a normal viscus. lock under acceleration or shimed super tight to be like a welded/ 2 way diff. a new shim from nissan costs around $10 and for someone thats done one takes only a few hours.
KAZZA do cheap locker diffs. 1 1.5 and 2 way for about $1100 which is cheap for a new diff centre.
so are you after a complete diff or just a centre. if yours is just single spinning than a re shim and some new lsd oil and it would probably be sweet as.
https://www.sau.com.au/forums/topic/206405-wtb-r33-diff/#findComment-3652708
Hey mate I got a weldy that has never been used, never even put it back together, the centre is still out of housing so you can have a look at it if you want, it comes with everything including, all you need to do is bolt it back together and away you go.
I welded it up at my old engineering job back in Melbourne and then decided to sell the car, give me a PM if you are interested in it mate
Oh and I also have a HICAS lock bar if you are intereted
https://www.sau.com.au/forums/topic/206405-wtb-r33-diff/#findComment-3653656
haha already had two 1.5mm shims in it :) kinda went bang on the way to devonport n had to get trailered home haha
Already got a HICAS lock bar but thanks anyway ;) how much u looking at for the diff?
https://www.sau.com.au/forums/topic/206405-wtb-r33-diff/#findComment-3654984
  • 3 months later...
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
