Nissan Skyline R32 (4 door)
White
Turbo
Auto
Approx 130,000 kms and engine is in top condition (no doubt)
Extras:
Vertex Front Bar
Tein Suspension
GTR Wheels set
Mechanical LSD (not clunky at all while driving)
3 inch pipe
Air-filter
Custom cat back exhaust
$6500 (Urgent Sale!!! Negotiable!!!!)
The reason why it’s cheap its because I’m heading back my home-town soon and don’t need this car anymore and also the front bar has a little crack and rear has small dent. However, this car with this kind of price and condition you won’t find it elsewhere. Moreover, this car is now at workshop doing service (engine oil, oil filter, brake pads, engine & turbo check and etc). I have all the resit with me that I can show you, so I’m a serious and honest seller here. Someone just take this baby home!!!
Call or Text 0433462117 for inspection (Anytime & Any day)
This car is located in Adelaide, SA
https://www.sau.com.au/forums/topic/206562-cheap-nissan-skyline-r32-4-dr-sa/
Is there anything wrong with it after the mechanical inspection and service you have had done?
i think it will not be any problem after mechanical inspection and service mate~so no worries,if anyone really keen just come and inspect and test drive,i will 100% sure the one who keen and tested this car will defitenely buy this skyline.Cheers~
Some Better pics pls.
Would you mind getting a leak down and a compression test done on the engine?
Thanks
ffs guys its 6k, where do you find another under 9-10k?
id snap it up if i had the cash on me dude, too cheap imo. oh and when you say tein suspension, do you mean coilovers or just conventional springs and shocks? .
Edited by toffy
Yeah man that's true,this is not a drift car or something,it's daily and fun car i suppose so no point for me to spend money check this and that.If ppl keen then just come and inspect and you see what you see mate.I'm after a sale now not because of the car probs,it because i'm heading back home town soon.
And sorry for the confusions.It's only spring and shock cheers~
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
