well i got RB74 front pads, and they squealed when no brake was applied, when applied it is quite normal for them to squeak. So i got my discs machined cos they were warped and had a lip, wow it worked! no more squeal. BUT i was at the track today, and after the day they now squeak again and very annoying! The discs i think are too thin to be machined again, wat do you reccommend ? new discs ? or could it be some thing else like dirt stuck between pad and rotor? :P please help me
https://www.sau.com.au/forums/topic/20662-rb74/
Maybe the pistons arent retracting all the way, my car had the same drama, you could always hear the pads rubbing on the rotors.
It wasnt until you pressed the pedal and the pad was in full contact witht the rotor that the noise went away.
Had the calipers re-built, now they are as good as new.
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-434555
When you machined the discs did you sand back the pads as well? Both pads and discs will become glazed over time, and if you scrub one back without the other, the one you scrubbed back will just get glazed again really quickly and you'll be back to where you started.
Could be the discs are too thin too, things will glaze up easier if there's a lot of heat involved. I think new DBA4000 discs are around $200 each. It may seem expensive, but they are probably a lot cheaper and definitely a lot better than the OEM items.
If you are really pushed for cash, maybe try buying someone's second hand discs? If you do, make sure you check for run-out. The factory items are 30mm thick when new, and need to be replaced at 28mm.
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-448548
Its not cheap, and you cant be sure that calipers need rebuilding until they are apart, then its too late as most of the expense has already been incurred.
If you need new rotors then that is the logical place to start. People laugh at the lengths i go to, to make sure my brakes are properly cooled down after each run at the track.
Its all you can really do to stop them from warping/cracking, that and not using the handbrake when you park it after a run.
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-448558
the pads were brand new when i got the discs machined, they hadnt been bedded in yet. The machining took the squeal away after the track day they started to squeak again. The calipers are fine, dont need a rebuild, its most likely the discs are quite thin so theres still abit of warp in them. I will live with it for now as its on and off thing (hard metalic pads create squeaks) im looking to upgrade to GTS-T brakes in the future without a stud conversion, the calipers can bolt straight on, they are just fatter and i might need new wheels :D Thnkas for the help ppls, Ben i dont think i will buy them, thanks neways im not sure if the GTS-T discs are much bigger? as the pads are the same size
Roy- i always drive around the track again using no brake to cool them down and i dont use the handbrake to park either, but its only the fronts which squeak, id say its the thin discs and new pads. with the standard pads i used them twice on the track and they were gone, ive used the race brakes once and they havent even lost a mm and that was real hard braking
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-450596
Originally posted by Roy
I love track days, it would be good if someone else would pay for the servicing on our cars:D
Sounds like you have it sorted, happy motoring.
You can get someone else to service the car you are driving by borrowing someone else's!
/cough
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-451053
My recommendation is slotted rotors too, since I have fitted them to my car, not only do I get a lot loss fade on the track, but no squeak either...more a low pitched groan under heavy braking as the rotor chops up the pads.
DBA's are good and reasonably priced, check their website
www.dba.com.au
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-451213
/cough
Oops, let me clarify myself, my car is the designated T-car, yours is the race car. Your the team manager, and im the backward a55 driver.:P
Hey, and i dont rev yours over 4,500 - 5,000rpm, you have seen how i drive my car when i get excited. Me in my car = Drive:mad:
Actually, i think i should just say thanks for the drives, and think of ways to thank you, need your car detailed?:P
As for Comp 15 pads, PM Silver-Arrowz, i think he uses them, may have been Comp 9s and whatever he is using is hard on rotors.
https://www.sau.com.au/forums/topic/20662-rb74/#findComment-453241
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
