Motorplex meet.
Guest Rhino
Another thread hereabouts was organising a skyline turnout for the 4th at the 'plex, but I thought a new thread was in order to try and organise a Sunday when a large majority of us can make it down.
It seems the 4th may not be convenient for a few ppl, so how about we set a Sunday and make sure we get a big Skyline turn out?? besides I think that the 'plex will be pretty busy for the first Sunday since the closure?
Sundays are pretty free for me so someone come up with a date and lets get a list of people who can make it. With Adam's (Killer-T)rebuilt R33, Chris's (R34) R34 GT-t, my GTR and quite a few other beasts the SDU/SAU 1/4 record is sure to tumble into the low 13 sec bracket, and I'm hoping for a 12.
Cheers,
Ryan.
https://www.sau.com.au/forums/topic/2067-motorplex-meet/
  • Replies 233
Ill be up for the r31 wagon record.
Car is still defected so i wont be going down there till its not, even though im not sure of their opinion of yellows cause my car is now in better condition then when i raced down there before.
Oh yeah a warning, your ET's are going to be very high if you go down there anytime soon. The track will be in **** condition. Its not going to be prepped and no meets in a long time = one slippery sucker
https://www.sau.com.au/forums/topic/2067-motorplex-meet/#findComment-38115
At this rate my car might be back on th road by then so count me in if so:D
Managed to repair the rim which was surprising:) need new tyre but thats it and i have to wait for the koni to come from Albury which shouldnt take to long.
HHOOORAAAYYYYYY:burnout:
https://www.sau.com.au/forums/topic/2067-motorplex-meet/#findComment-38673
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
