Motorplex meet.
  • Replies 233
I've got a blitz dual SBC spec S. Low is 0.6bar and high is 0.8bar, been tuned by one of the best in the business (imho) and I havent had any detonation or pinging, but its also a lot colder than summer, so I'll be reverting to 0.6bar (I think stock is 0.5bar anyway) when summer rolls around and when I can afford it I'll pop in a front mount i/c
Nope, I'm tired of people argueing about who the best tuning shops are and who are crap and use sub standard methods, plus I dont like naming names as a couple of years ago I almost got taken to court for a post on hotcopper.com about the company I was working for. My suggestion is look at what projects they have built or had a hand in.
Rob
Originally posted by rob77
I've been to 3 tuning places and I'm very happy with this one.
Rob
Rob
Not that it matters to me cos I have my own favourites , but you can't get into trouble for recommending someone, only if you bag them without just cause.
IMHO I'm sure the tuner would be happy for the free plug as most times all you hear is how bad someone is, not how happy you are.
Ken
also might add to the list of places to try
i've been to;
psi
cypher
formaz
and xspeed
have heard of
barry's automotive
performance turbos
west racing
and a couple others i can't remember
in the end it comes down your personal experience at a place. a name want hurt.
ps for your 1/4 time on those boost levels low to mid 14sec passes with your mods
Count me in, so long as its fine and cold. Just had a boost controller put in and I want to improve on my 14.82 I set last-time (completely stock, cept for a 3.25" cat back system). I'm hoping for a very low 14 or high 13 with the extra boost.
Rob
Hmm I can't see you getting 13s with cat back and a bit of boost.
My first run was 14.5 - that was with just cat-back and pod filter.
now i have full turbo back exhaust with hi flow cat and 10psi (.7bar)
I am still not sure if i will hit 13s or not....... probably depend on the conditions ie how slippery the track is and how cool the air is.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
