If you went Koya you should've gone those drifteks? Or whatever it is those are that everyone uses. They look pretty decent i guess
u said the answe right there......i dont/didnt want my car to be like everyone else.................................:P
So now your rims are up for sale.... Please tell me you not selling them because you got negative feedback on your question of what does everyone think...?
Dude, you probably asked the wrong question, you asked people for their opinion and you got it...
It's supposed to be your car not everyone elses, do what you think looks good, don't worry about pleasing others.
Oh really, it's up for sale?
I agree with 75coupe mate. Don't listen to what others say, if you like it, keep it. You're the one driving around with it all day long, not them, but then again I do see why you would want to sell. Probably because other skyline owners will see you with 'sex spec' wheels and think it looks shit. :D
+1 to everything 75coupe said though, you asked the question and you got the answer.
mate agreed, dont sell em just cuz we all said they dont look the best. im sure theres alot of ppl out there who do think they look decent.
if i listend to every wanker on SAU i wouldnt even have a car.....lol still remembver my prime days on SAU....ahhahahahhahah
nehoo back to my point. if u like em, keep em buddy.
its all good.....had some issues with my suspension and stuff and could have done with the extra cash....
i really didnt car what people thought so its all good.....it was something rarely done...and as far as im concerned it could have looked alot worse....so yeah...thanks all the same...
but yeah, like i said it didnt bother me and they were put up for sale purely cos i could have done with a bit of extra cash and stuff like that.....but its all good....they are on there now.....i kinda dont keep my rims for long anyway....i like to keep changin them and finding newer, better and nicer rims....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
