Hey Ben!
yeah it was a good day, it cleared up a bit in the arvo which was great!!
And as you can see from one of the photos, I had a bit of an incident! :) lol
edit - just had a look at natsoft, w00t, under 40 seconds!!
No worries guys, nice to meet you too. Glad you all had a good day & braved the ordinary looking weather.
The event ran well, with no problems or serious 'offs'. Quite a few spins, but everyone drove themself back out again... thumbs up to the dude in the big tank fairlane thing (the big red/black thing in the background of one the pics) who was doing some impressive dorifto action around the back of the track!
how many runs did you all end up getting?
great day to get out and have some fun, bloody slippery in the morning (or does the back end of a skyline just experience some sort of mythical attraction for the edge of the track :rofl:) but the rain stopped mid-morning and it dried out. I finally got a couple of decent "grip" runs in around 2/2:30 and was happier with my line towards the end. No idea about times, if anyone has them fill me in :D
No spins, but some rather interesting moments heading into the first corner. Great day though, thanks to frogman for posting details and good to see everyone :D
Yeah, had a great day, considering the weather.
Dissapointed that we couldn't get a second run in the motorkhana. I will be doing the dash lap next time only.
Loved doing skids in 2WD mode.......
Chris, no problems mate.
Could not believe the amount off mud that was collected, after hosing down....
heres the results from Natsoft, but doesnt have cars listed :D
http://www.natsoft.com.au/cgi-bin/results....03/2008.OPGK.S1
I think 1st & 2nd were VWs, then Chris(Skyline) then another VDub, then the blue VW/WRX. Should know more after tonights presentation/dinner...
Edited by frogman
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
