Sounds awesome guys. Looking forward to it.
May even be able to get somebody to have a look at my car and see why its running like rubbish. I have an intermitant problem i cant find. The car still boosts up fine but it sounded like the exhaust was backed up or blocked and there is a load roar like noise. Its not like your normall boost leak and i cant find one anywhere. its really unresponsive and thought my cat had packed it in but thats not the case. It runs fine without it.
  • Replies 163
Posted Images
Yeah I should Turn Up I guess.
Im from Banora Point (basicly Tweed) So we could even get a Tweed Crew Going.....JKS
Im broke till saturday lol so hopefully Ill have some fuel left.
But ill come say Gday.
Andrew
im in banora aswell. im really a true coastie but im down here for a while until i go overseas. how come i never see skylines down here!!!!??? where are you!!!!!! lol
hey guys, ill be working till 8 but will just be down the road at the q store so i mite pop in if ur still there just to have a look and see how many people turn up. look out for what will prob be the only 4 door 33 there. irish.
Long33 - I drive a 350z blue coloured 33 with URAS NS-01 Wheels and a busted up front bar and passenger side guard from when a kangaroo kamakazied itself into the side of my car in victoria.
btw I live off Darlington Drive, How bout yourself?
Cant say ive ever seen you car around.
See yas All tonight :D
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
