My skyline still being off the road atm, my daily shit box has decided to blow the headgasket (well the new gasket didnt reseal) again, and i CBF pulling it down again to redo my stuff up.
Quick n easy - Does anyone know of a cheap (like im talking ~$500) runabout that is reliable - yes there are reliable $500 cars out there.
I just need something to get me to uni n back 3x a week, so not expecting a XU1 thats been stored for the last 40years in mint. If you know of anyone who may have one, or have one yourself, then let me know asap.
Area doesnt matter, i cant get to most places, as long as it aint outback.
There used to be a thread here with cheap cars going, but its died....wish it was still active...
Thanks for any help.
:P
https://www.sau.com.au/forums/topic/207852-anyone-know-of-a-cheap-car-going/
My family has an Escort that they would like to get rid of. I was driving it when my line was off the road. It's a 1300 Auto- Euro slow as #### but better than walking.
PM me if you're interested
http://www.nissansilvia.com/forums/index.p...howtopic=289662
cheap daily + u can slide slide slideeeeeeeeeee
that already sold bud, i tried to buy it for winter :P
have you tried a chemi-weld fix on you hack, it does amazing things my stanza went for at least another 10 months after using it!!
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
