Make:Nissan
Model:R34 GTT Turbo Coupe
Milage:94,000km
Transmission:Semi-Auto (4 Spped Tiptronic)
Colour:White
Complied?Yes
RWC supplied?Yes
Currently registered?Yes
Price:$16,500 ono
Contact:Rob - 0401 636 847
Comments / Modifications: This is a nice neat example of an R34 GTT Turbo Coupe. Xenon Headlights, No wing, Clean interior and no Jap ciggarette burns in the trim. It has what looks like an Apexi cat back exhaust (with removable silencer), Pionner headunit, Pioneer Splits, Pioneer Stacker etc. Great smooth car to drive.
Images:
Edited by DRFTD_32
https://www.sau.com.au/forums/topic/207940-r34-gtt-turbo-coupe-1999-16500-ono/
