HI guys, I will be getting my HKS GT2835 Pro S soon, just wondering, for the people that have it, does it still have that nice spool jet sound that the standard turbo provides?
You'd think it would be louder since it's a bigger turbo, am I correct???
I would hate to have it installed and it makes minimal spool noise, Id be heart broken! lol :)
cheers
And what about the flutter, I love my flutter... Will the flutter be louder than the standard turbz? I should be, bigger turbo yeh?
I would suggest a Recirculating BOV, as it will make your turbo last longer.
Also, sounds like you want attention?
Cops will love you.
This one is better:
http://users.on.net/sau/pacey.avi
Port shrouded is a "windowed" compressor cover
Looks like this:
Lol, still dont get what you mean, that just looks like a normal turbo to be that dont have a filter and not connected to the cooler...
ps. your vid didnt work :)
Cops will love you.
F#$k recuirculating, I just wanna hear that biatch flutter.... Took of the plumb back stocky BOV, flutters real good.
So will the HKS GT2835 Pro S Flutter louder?
ANd also, will the HKS GT2835 Pro S turbz maker the spool sound yours did?
CHeers
spool will be louder than stock as the wheel is steel, your pushing much more air, and running a pod (no doubt)
all these things will make it a fair bit louder.
My old GT30 sounded like an aircraft once i plumbed the gate up :)
i've got a link for my vid somewhere, but you cant hear a lot over screamer pipes :)
This one is better:
Looks like this:
Im about to bolt on one of those,external gate though :)
CHeers
You dont want it to "flutter" your turbo wont last long.
lancers have mad flutterz and spool noise. Buy a lancer and its a straight fit for a triton diesel turbo to go on. Will be faster, be more cuztom, and flutter way more.
You dont deserve a nissan
Vid please! What were the specs of that motor?
ok... found it Click me!!!
GT30, 45mm gate, Nismo (factory GTS-R) manifold, RB25 (built), factory head/cams :down:
24psi/104 sunoco, thats the major stuff anyhow
GT3040?
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
