Hello All,
Im thinking my car needs a few mods to give it a bit of a kick up the arse. It currently has a turbo back exhaust, shocks and spings and a pod...thats it!
I do know what I can get for it but I'd like some opinions on parts which are more needed over other parts. For instance, I was thinking about getting wheels, strut brace and front mount. Im not saying I have all that money now for them parts but they were going to be items I would save up for. I am now thinking there are parts that would be worth getting over them, like a PFC, coil packs and what not.
Anyone have some ideas that will get me a little power over looks, I dont need wheels right now so there is 3k saved for something else.
Hit me with what ya got :)
https://www.sau.com.au/forums/topic/208033-need-some-more-opinions/
Depends what power you are chasing. If the car already handles fairly well and your not looking for over ~200kw get a front mount, some form of engine management/ piggy back unit (Emanage ultimate, SAFC - PFC's for RB25's are getting to the $1300+ regions these days if you can find one) and get the car tuned.
If you want more power than that your going to need to start looking at an upgraded turbo, injectors, a Z32 AFM, and clutch. A basic piggy back unit like the SAFC will not allow you to run these modifications correctly.
So maybe a PFC would be a decent option at this stage. Ive been hearing for a while now that the apexi pfc's are very hard to come buy. Is there any other brand that may be as good but maybe cheaper?
Front mount. boost control, and engine management. If you are keeping the stock turbo and cams there realy isnt any point doing much more than that to the engine as there are very minimal power gains to be made.
But if you do feel the need to do the cam gears leave the intake cam alone as the VCT gives you a lot more mid range power than an adjustable cam gear will.
Think about how far you want to take power now, so you don't muck about with gear you'll loose money on, selling later.
If your not looking to change turbo, then don't bother with a front mount that will increase throttle delay. The R34 GTT units replace the side mount one and flow to about 220-250rwkw which is already a good 20-30 over what your stock turbo will do at safe pressures.
I reckon its not worth a munched engine, due to failed stock turbo. A GCG style highflow, signal bender, maybe a adj FPR to sneak base pressure up a bit should see you 220-240
You generally cant change injectors with a bender though, so once you need more then the stockys can provide, it's AM ECU time.
Spend an hour going through http://www.skylinesaustralia.com/forums/Rb...html&st=360 and see if you can get a ride in someone's 240rwkw setup. If you want more, then start planning for a much larger turbo, ECU, fuel upgrades, clutch blah blah.
Edited by GeeTR
So am I able to get a GCG highflow turbo without any other mods or will that require a front mount, ecu or anything else? By the sounds of it I could get a GCG for the same price it will cost to get my FMIC supplied and fitted??
Last time I checked, GCG highflows were $1900, you can get a Garrett BB unit for cheaper than that, especially if you know somone who works for Repco (staff prices).
Probly one of my favourite mods was after having the front mount put on, I had a bit of lag, so i got my manifold cut and shut and now it faces forward which reduced piping by about 1 meter and basically got rid of any lag. But for the price of some of the purpose built manifolds of late, that would be another option. Also with the cut and shut, you need an aftermarket computer anyway cos it will lean out some cylinders, but the purpose built ones you dont.
you can get better turbos for the same money as a highflow and sell your stock turbo off if you upgrade. if your looking for a whole turbo kit you cant go past the HKS GT-RS kit $2900 from Sliding Performance (clicky for the link) and it comes with everything to bolt it onto the engine
cam's make a big difference...
On a rb26 (not really anything to go off i know) with cams pump computer, injectors + a little more boost you can get some really high figgers off the unopened bottem end. Something to consider though is how long you want to engine to last...
Stevo -
Simple effective power mods:
Step one: Front mount intercooler kit (decent size) about $600 - $1,000 depending on brand.
Step two: GCG Garret turbo kit (you can get bolt on RB25DET kits that are pretty straight forward to fit) $1900 - $2200 depending on size.
Step three: Splitfire coils + cooler spark plugs (if you put a bigger turbo on and turn the boost up you can easily blow out the spark from standard coils, helps to limit pinging aswell) - $750 - $1,000.
Step four: 550cc injectors (more boost needs more fuel) - $750 - $1,000 depending on brand.
Step five: Power FC - Best bang for your buck computer you can buy (to control it all) - $800 - $1,000.
Have your exhaust looked at, dont just assume that it will flow enough for a bigger turbo and modified engine, the one that I got with my car was almost completely blocked and had to be replaced.
Most mods will cost you a few hours labour to fit if you dont want to do it yourself - Call the boys at Trojan and talk to them about that.
With those mods you should see about 240rwkw (depending on the tune and what size turbo you go for).
You dont need an aftermarket Fuel pressure reg, or a Z32 air flow meter unless youre going for big power, otherwise the stock equipment is good for about 240 - 260rwkw...
Happy modding :turned:
P.S. I have done all of these mods to my own car, had 4 dyno tunes and almost every problem you could imagine, so feel free to ask me if you have any questions. :)
I cant help these things!!! There is just something right about it!!!!!
mmmmm next project s4/5 rx7 or RX2 coupe / 4 door with 13bbp turbo with T66 106 or just a bridge.... bloody house wish that was finished.
They's a lot more then 1K though :turned: And if 240'ish ends up being enough, then he saves $$$.
Not evry feels the need to slap a 500hp HKS unit on Race *cough* lol :)
Edited by race_snooze
Mick is spot on, its all simple enough to install, relatively cheap and you can have a lot of fun with that power. Or you can head the other direction and spend that sort of money on suspension,wheels and tyres and go fast round bendys instead.
Hola, como estas?
I have found a turbo I think would suit thhe power I am after. Does anyone have any experience with the garrett GT3071R or know a little about it??
Gracias
http://www.tweakit.net/shop/product_info.p...a038cedaaa05874
Thats using your noggin. Much better deal than the GCG highflow. P.S, I have decided to stick with the Power fc for a little while so I can at least drive it, but I have seen a few in the classifieds recently.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
