Stolen from Performanceforums, who stole it from some one else.
Hello all,
It is with a heavy heart that I come on here and write this. I just wanted to stop by and thank everyone for their comments and prayers. A friend told me about this forum and I stopped by last night to read all of the posts, and what I seen made me proud to be a hot rodder. Thank you one and all.
Boyd was a great man, not just because of his accomplishments, but, because of what he believed in and did. I was with him for 8 years and seen the man for who he really was, not what was seen on a TV show or a brief encounter. I can tell you all he truly loved hot rods and enjoyed seeing the cars that folks brought to the many shows we attended. Here's a good example of how he felt, we were at a small show for an appearance. Him and Jo were taking a break before heading out to start signing autographs and hadn't had a chance to see the show yet. I had taken a quick walk around to see some of the cars and when I returned he asked how it was. I made the comment that some of the cars really didn't belong in a car show which quickly brought a response from Boyd. He told me " these guys work hard on their cars and they are proud of them, that's what matters, and it is not for us to judge them but to respect them for the hard work and effort it takes." He of course was right and I knew better, just one of those stupid comments we all make sometimes.
I learned a lot from Boyd over these past 8 years and, although I wish I could have more, I thank God I had the time I did. I am proud to have known and worked for the man and feel very blessed and lucky. He is and always will be a legend in our community, and will be deeply missed.
Again, thank you one and all, and I will pass along the wonderful thing you all have said on here to Jo and the rest of the family and folks at the shop. God bless you.
Todd Emmons
Boyd Coddington's Garage
https://www.sau.com.au/forums/topic/208086-boyd-coddington-dead-age-63/
:) Great loss to everyone, very sad. Watch his show all the time and love the cars he built. A very influential man in todays customising society.
RIP Boyd
So very true mate.
Edited by PM-R33
From what i have read/ heard it seems he had a fall at home. Was admitted to hospital and later released. Only to be re-admitted a few days later.
Im guessing maybe some form of infection or some such. in any case, while i didnt really rate the show, he did certainly create some great vehicles
wow... thats bad news. One of my favourite shows is American Hotrods. I love it that much I went to check his workshop/garage and his car collection in California last Sept. Has some great hotrods on display to the public.
His work was truly amazing up close and its a shame his gone :D
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
