Item:GT 3540 .63 TURBO
Age:Less than 2000km old
Condition:as new
Price:1450 FIRM
To Fit: (What car)rb25 or bigger
Contact:0421 986 981
Comments:never been over 18psi which isnt even in its efficiency range so heaps more left in it. Just a tad big for what i want to do. Made 295kw on a full standard rb25.
Edited by LTHLRB
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/
  • Replies 56
yeah second hand gt3540's are worth anywhere from $900 to $1200, i picked up a brand new one for $1450 2 weeks ago.
drop the price to 1200 and you should be able to get close to that price
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3683980
this turbos hasnt even been pushed into its efficiency range yet. So its barely even been used. I payed 1800. Polished it. Put the metal elbow and did roughly 1500kz. So its still basically new. But i am negotiable. Be realistic im not gona go too low.
And u cant get them brand new from a shop for 1600. Min is around 1750
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3684688
approx 18psi. i dont want to push this any further because i have a single plate clutch and obviously the std bottem end, if it was a built engine with a twin plate, i would go up to around 26psi. For street this is more than enough to scare you.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3688505
To do the same setup i have done with this turbo is not a costly exercise.. Turbo cost me around 1800 then delivery, manifold was 250 then hadto modify it to be perfect, gate was 570.. You could use cheaper parts, but i dont want to stuff around fixing things twice, so i went braided everything and made another wastegate outlet with a screamer, full 3" exhaust, 4" intake pipe, Put the elbow on because if i was to put a silicone bend it would melt.
So realisticly the figures to set up everything would be roughly 3,700 or so doing it right.
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3694845
So your including all of that + turbo?????
https://www.sau.com.au/forums/topic/208103-gt-3540-fs/#findComment-3695077
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
