I doubt I went over 100, so my guess is on just below 30km/h over the limit.
I just had a look at the Perth Road Safety website, and it says 25-40km over the limit = is now a $750 fine??? and increased to 5 demerit points?
Can anyone confirm this? How much am i looking at?
My first speeding fine in 2 years; maybe it was a good thing I got caught =(
https://www.sau.com.au/forums/topic/208219-rougly-30km-over-limit-fine/
OK NVM, those are the new penalties starting from March 1. But I have a question, if the fine is processed at a later date and arrives AFTER March 1st, it will still be under the old penalty as the incident happened before right?
More than 29 km/h but not more than 40 km/h
Was $350 Now $700
o_0
what's the web add for the perth road safety where you checked? i tried the obvious but nothing came up
http://www.officeofroadsafety.wa.gov.au/in...topicsPenalties
Note they are the NEW penalties which come into effect on the first of March.
Edited by Meecrob
I've always thought you lose your license for a period if its over 40 or 45, not sure. Can anyone back this up?
Im very sure its 45 and over is loss of licence. I got done for wreckless and on the summons it said exceeding 45+
Yeah I guessed it was that much because I remember Perth having much lenient speeding fines as opposed to the other states.
So can someone confirm that around 30km does NOT equal to a loss of license?
Oh yeah before someone flames me for speeding, there was no cars on both lanes, and it's so rare for me to speed =(
you have over 3 months till you recieve your fine any way so stop stressing
Man to be honest I don't care about the fine at all; I'm more concerned about the loss of license IF that is the case.
Does anyone know for sure if 30k over results in a suspension of your license? Even for 1 month?
You wont lose it for 30 kmph over. . just a fine and points
45 and over is wreckless/dangerous and points and fine and court and cought fees lol
Thanks dude, just what I wanted to hear.
I think I was still lucky that I didn't end up flooring it completely or had my car been faster xD
Thanks guys for the answers!
think it's 150 n 3 dermerits still
don't think the new thing has kicked in yet ?
I''m not 100% sure whether i was below or exeeding 29km/h, thats a $100 difference.
As for a $150 fine, I'm not sure where you got that but if thats true that even better =D
