Nathan Weissel, winner of the 2007 NSW Drift Series and 8th overall in the National Drift Series, has joined forces with Federal Tyres as his major sponsor to contend the 2008 series.
After competing using Federal Tyres in his early days of drifting, why has Nathan switched back to Federal Tyres?
“I tried other brands but the Federal tyres are still my favourite,” said Weissel, “they give me the best level of grip and control and do not suffer with heat like other brands.”
Nathan will use Federal 595 Ultra High Performance tyres on his Nissan Skyline R32, with 235 / 40 ZR18 on the front and 265 / 35 ZR18 on the rear.
“Federal Tyres engineered the 595 Competition Series tyre to handle the abuse of drifting,” explained Brett Quodling from National Tyre Wholesalers. “The 595 provides responsive performance at high speeds and exceptional adhesion and control when needed while withstanding excess heat from wheel spin.”
Nathan will compete using his new Federal Tyres at the first round of the 2008 Drift Australia Series at Symmons Plains Raceway in Tasmania this weekend.
Special thanks go also to ACL Race Bearings, Wolf ECU's, Motul Oils, Stamford Wheels, GCG Turbo's and Sign Design for their support.
Media contacts:
Nathan Weissel
P: O2 Auto Sports - (02) 4423 0977
National Tyre Wholesalers (Australia)
Brett Quodling
P: 1800 050 060
E: [email protected]
www.federaltyres.com.au
www.driftaustralia.com.au
post-16772-1204201119_thumb.jpg post-16772-1204201142_thumb.jpg post-16772-1204201161_thumb.jpg post-16772-1204201190_thumb.jpg
  • 6 months later...
Pity you can't buy those tyres anywhere, only the lower load rated and speed rated tyres at local shops, with what the Federal website indicates is a different tread wear as well. (Well in 17's anyway)
    • A quick google, and some E39 users have found pulling my sensor out/apart and cleaning it alleviates their issue. Then get the oil warning to go off, and once it is off (from the sensor saying it was unhappy) some find they can just unplug it and it is happy to just keep going now. Maybe give it a crack? If you can actually pull the sensor apart, hit it with some electrical contact cleaner.
    • Yep. In the E39 it's slightly different than the others. Honestly I'd just leave it but every time I drive the car it tells me oil is low and that just makes me check the dipstick. It is a BMW Afterall and it tries to expel it's own oil regularly.  Thankfully it's not like my E90 that has no dipstick at all so you just gotta trust it.
    • Was that also a typo? $350?! Just typing "BMW oil level sensor" and prices start out a lot more sanely than $350. I'm guessing it's a sensor used in one low volume model only or something?
    • They kept the product number the same, so we "didn't pick it up when packing your order". If you packed the order, you clearly saw the box wasn't Hella...
    • Actually, the equivalent skyline part is both cheaper and simpler, maybe you should come back from the dark side?
