This is how mine ended up.
used heatgun to mould it and foil backed foam for insulation from the motor
top is clear so i can see how dirty its getting, also dont need insulation there
same here, thats why i used a mixing bowl and a heatgun to shape where it goes in.
look closer at the second pic, see i put the afm right in there.
heres another one, with it installed
JBonDSS, I get heaps of air because I also have a CAI I made... you can check out that tutorial too wink.gif
Obvesouly there will always be air going to ur pod, if it was indeed air tight, your car qould seize up, so no matter how much you think your headlights seal off air, they never could completly....
In terms of air, you are assuming I have a spare Intercooler hole in there under the heatsheild? My car came as a non turbo....so I had no holes to begin with....I turboed it so We had to make one hole for the FMIC ... then for my CAI.. I had to make another 1... it is so easy...and I know about the legalities of this... but you cannot see inside the tinted perspex... and know one knows... biggrin.gif
Power wise I didn't really notice much difference with the heatsheild by itself... with the heatsheild AND a CAI... i have noticed a fair bit more torque at top end... which is fun tongue.gif you can tell it works well because you can get out of the car, whip open your bonnet and feel the heatsheild on the inner side and its cool.... while the rest of ur engine is at 80+
Adam
wow i am really intersted to see if there was a change on the dyno, i was under the impression that cai had no effect on turbo engines because as soon as it hits the compressor it heats up thats where the intercooler comes to play
it looks mint thought mate, you should make a few up and sell em off ;)
Yeh a CAI isn't going to make any difference to your power figure. Where they do help, is with heat soak. Do a few hot laps around a track and a good heatshield/CAI will help slow the heat soak of the system.
Ran my car on the dyno over and over on the weekend and no heatsoak issues, ran within 1hp of the power figure.... Airbox was warm but did the job!
  • 5 weeks later...
  • 8 months later...
^ looks neat with the aluminium.
How did you go about bending the aluminium? I want to make mine out of it, but i don't know how to bend it without an actual metal bender lol. Otherwise, i'd have to opt for the perspex one, which also doesn't look bad
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
