Hey guys,
I have a brand new Trust/Grex Oil Cooler Kit to suit BNR32 for sale which I no longer need.
This is the equivilent of the NS1010G ('Radiator Front') kit and is the non-relocate type. The kit includes a Trust 10 Row Oil Cooler Core, quality braided lines and Earls light weight anodised fittings, Trust Oil Filter Sandwich Plate, and of course the nuts, bolts and other fittings needed for installation.
The Sandwich Plate also features an inbuilt thermostat and has the provision for oil pressure/oil temp sender installation with quality screw in bungs included just in case you aren't running aftermarket gauges or sensors.
Trust Oil Cooler Kits are widely recognised as one of the best quality Japanese Oil Cooler Kits available, and this one is going to waste sitting in my garage so im hoping someone will give it a new home.
In the interest of a quick sale, im asking $495.00 FIRM which is VERY cheap - Someone take it away before I change my mind!!
Pickup is available at North Ryde in Sydney, and I will post if requested as the buyers expense.
yep, as long as RB25 use a filter with the same thread size and pitch as a 26 then it will fit. also, the lines have removable ends so you can cut the line length to suit and re-attach the ends if need be. trust oil cooler kits are the shit. :laugh:
  • 3 weeks later...
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
