I got hold of some M-type front brake for my 32. but i just got the calipers and rotors and a few fitting that go with it....
this is from http://www.skylinesaustralia.com/forums/R3...ml&hl=brake
To do conversion:
a) type-m 4pot caliper x 2
B) type-m brake lines and all fittings x 2 (mandatory!) <----------------------------------- ZOMG! My lines were cut!!!!!
c) type-m spec discs, which will generally be much thicker than the non type-m
d) brake fluid bottles x 2 (DOT 3 or better rating) - supercheap auto
e) brake bleed kit (supercheap auto)
"In a way this is one of the more fiddly parts of the process. Make sure you have the type-m lines or equivelent, as the non type-m have a different thread pattern on the caliper end and WILL NOT work (trust me I tried)"
So that means i need M Type lines from somewhere?
has any1 done this conversion b4, any help would b appreciated!
https://www.sau.com.au/forums/topic/208544-oh-noes/
What are you trying to do? Just convert to the larger 4 pot brakes?
That person you quoted that you'll need to get the bigger brake's lines as well, so I guess you'll need them, but doesn't hurt to try if your smaller brake's lines fit. You'll have to bleed the brakes, but that's not hard work.
https://www.sau.com.au/forums/topic/208544-oh-noes/#findComment-3688369
  • 4 weeks later...
Hahah, yeah, if you've got a turbo 32, you'll most likely already have the 4 pot brakes.
im not sure about non-spec GTS-t's, i think they still ran the 4-pots but smaller? i cant remember, but by the looks of his sig his is a m-spec anyway going by the front bar in the image (m-spec front bar)
https://www.sau.com.au/forums/topic/208544-oh-noes/#findComment-3768722
Yeah, the GTSt's that weren't type-m didn't have the 4 pot's as factory items from what I know, but most turbo models being brought into Australia are type-m anyway (I'm pretty sure :D ).
https://www.sau.com.au/forums/topic/208544-oh-noes/#findComment-3770306
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
