hey
I just though I might see if there is any interest out there for my R33 Impul 4 door.
1993 Impul R33-R Skyline 4-door Sedan
Silver
75 000 kms
perfect condition
This one is number 67 of 100 made. Nissan gave these cars to Impul to put all their goodies in, and its loaded with all the good impul stuff. you name it, its probably got it.
link to review
http://www.nissan.co.jp/U-PORT/MAG/R33_R/index2.html
link to pictures
http://impulr33r.boostcruising.com
looking for mid 30's, if anyones interested pm me, or email me at [email protected]
https://www.sau.com.au/forums/topic/20880-r33-impul-r33r-4-door/
  • 3 weeks later...
  • 1 year later...
Hi Matt:
My name is Paul, and I own the first Impul R33-R that arrive in OZ, and was featured in High Performance Imports magazine a couple times. I made several changes since it appeared in the mag, it has an RB26 and front mount intercooler, new turbo, yes a single T88 and a few more things bit I'll be mentioning for a few days. I tested the car at Willowbank and best run was 11.04 quarter mile. At the moment is the fastest 4 door skyline in oz. and still has the original Impul body and interior. I don't know if u still have yours, but I hope U still do. PAUL ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
