why dont u just buy octane booster?
+1
even if WA got higher octane fuel, there would be such a low demand for it, it would be taken off the market just as quick as it arrived.
That, plus the fact you would be paying through the roof for a tank, would see the already small market dry up very quickly
ps: lol @ Tomei_32 sig....hahaha
Edited by Go 33
https://www.sau.com.au/forums/topic/208830-102-octane/#findComment-3695018
Octane booster doesn't really do all that much, in addition to it being another bunch of crap to add to already average fuel.
Octane boosted fuel will never be as good or as clean as true high octane fuel.
https://www.sau.com.au/forums/topic/208830-102-octane/#findComment-3695026
4.10 a litre lol
Thats what we pay for ultimate anyway isnt it?????
14c a litre extra is such a rip off its bullshit!
Does the cost of that little extra refining go up each week above the crude oil price??
I doubt it.
Rip off merchants!
Thants why monopolys suck, but i supose a duopoly isnt going to be any better they will just fix the prices, thats why an independent 98 would be good.
Just a shame we live in a lil country town with 1 refinery.
Bummer
https://www.sau.com.au/forums/topic/208830-102-octane/#findComment-3695968
Just following this thread on fuel, Im working Jandakot airport and can sell a drum of avgas not a problem,you will need to mix the fuel, haveing higher lead content and all. Falcon GT club are pretty keen on the stuff, they,ve been here heaps of times.
https://www.sau.com.au/forums/topic/208830-102-octane/#findComment-3701114
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
