Make: Nissan
Model: 180sx
Milage: 176xxx
Transmission: Manual
Colour: Gunmetal Grey
Complied? Yes
RWC supplied? Neg
Currently registered? Yes
Price: 9k Neg (10k with rims) willing to Swap for a 4-door of interest something Jspec VIP
Contact: PM - mobile: 0422611803 anytime before 10pm sms after 10pm
Comments / Modifications:
Engine Mods:
- Blitz FMIC
- t25g Turbo (recent reco from previous owner)
- 3" HKS Dump
- 3" Front Pipe
- 3" Hi Flow CAT
- 3" CAT Back Exhaust System
- Carbon Fibre Cooling Panel (Added 05/01/08)
Driveline Mods:
- Exedy HD Clutch (recently fitted)
- VLSD
Interior Mods:
- Greddy Boost Gauge
- Apexi Pen Turbo Timer
- Later Model Front Seats
- Pioneer HU (added Pioneer DEH-P8950BT - 29/12/07)
- Front Splits (added Pioneer TSC-1625 - 29/12/07)
- Rear 6" 3 ways (added Pioneer TSE-1695 - 29/12/07)
- Immoblisier
- Central Locking
- Nardi Steering Wheel
Exterior Mods:
- HID Hi/Lo Kit (Added & Installed 02/02/2008)
- Clear Side Indicators
- 18" Lowenhart LD1 Rims
- Yokohama Avan Semi Racing Slicks
- Tinted Windows
Suspension Mods:
- New Pineapples
- Rear King Springs (changed to JIC Coilovers added - 28/12/07)
- Rear KYB Shockers (changed to JIC Coilovers added - 28/12/07)
- Front Cusco Strut Brace (added - 02/1/08)
- Front Adj 5-Zgien Shockers & Springs
Since owning this it has had a service when it hit 175thou km also for RWC had front and rear pads changed and i can't remeber it it was front or rear dics but one of them was machined, rear main seal changed (this is when i found out the clutch was brand new), rocker cover gaskets, oil, oil filter, NGK plugs, coolent flush all carried out by my mechanic (happy to supply number)
Also i have the following not fitted to the car and will be an extra cost if wanted at time of sale:
- z32 AFM (good used condition) $180
- Apexi AVC-R (New In Box) $450
- Blitz BOV (used, painted black but can be returned to the chrome if one wishes) $125
- K&N Pod filter $30
- Rear Cusco Copy Strut Brace $80
Spares:
- Front SR20 Hubs cailpers and Discs
- Front & Rear Bars White (was going to use these if i ever did a track day so i didn't damage the matching ones)
- 2x Rear Pods one set black missing the rear center lip and one set greeny-yellow with center haven't decided which to fit so come as is both need painting and can put you on to a great painter
NOTE:
At the moment the car doesn't have the stock airbox as pictured i took it out to help my friend for his RWC it will be swapped back shortly and i'll return his intake pipe and car will be sold with the Stock Setup
Air box will be swapped tonight but im considering getting the piping done anyways :yes:
please feel free to ask any other questions its a genuine car, genuine reason and im not hiding anything.
ALSO:
if the car doesn't sell for what i want or a suitable swap doesn't occur i'll be keeping and trying later down the track i really love this car i know CAs aren't the 'In' but its great fun to drive and it was my first proper import anyways thanks
UPDATE:
i've just found out the LHR tyre has a flat (caught a bollocksing screw in it at work on saturday!) so i'll change both rear tyres to a harder compound - theres semis are tricky in the wet anyways!
Fronts will stay the same
Images:
Edited by hitoriko
eoi only swap this and cash my way???
mods are basic
fmic
tein coilovers all round, flex back, hr front.
full 3 inch exhuast turbo back.
gizzmo 4 stage boost controler.
18" rims all round, 265 back and 235 front.
tinted windows.
greddy turbo timer.
kenwood mp3 cd player.
full year rego
Brand new extreme brass button clutch with 1500kg pressure plate
replaced 5 speed gb, wrecker said only 30000 k's on it, with 3 month warranty.
Cheers
Michael
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
