power and mods list plz
edit.. any problems with heating or boiling problems due to the p/s being pretty much on the turbo???
even i had to move mine.
so im guessing no probs?
Edited by r33cruiser
:nyaanyaa: no heating problem at all!
just a few mods to entice all you rev heads!
rb25det
2.7 ltr stroker kit
tomei 2.5mm copper head gasket
tomei forged pistons
tomei titanium coated rings
hks cams
hks cam gears
TD06-25G trust turbo
trust 65mm external wastegate with 2" screamer pipe
trust stainless exhaust manifold
os lightened fly wheel
os triple plate clutch
os two way diff
so far car has made 375 rwhp at .05 bar or 7psi
and is bulit to run at 18-24 psi
so should make heaps more when we tune on full boost!
plus heaps more!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D
Edited by japspec r33
Very impessive looking car you have there and the the list of mods blows me away, well done. I know of 2 people who have had issuses with having the AFM that close to the turbo, have you had any?
if you look closer you tool you will see the AFM is miles away
from the turbo!! :D
fark you cock sucker learn some farkin manners, its not miles away its closer than the people that had thier own issuses, seems like you have some as well maybe you need to see some professionals about it.
fark you cack sucker learn some farkin manners, its not miles away its closer than the people that had thier own issuses, seems like you have some as well maybe you need to see some professionals about it.
here is another pic for all you dummies out there!
you will clearly see that the AFM is about two feet away from the turbo! :D AGAIN!!!
So I take it you have no issuses with it being where it is, thats good, I was just asking a question relating others experience, maybe they will post their own reasons and then you may see what a pratt you are being about this issue.
And are you, This guys fan boy. Do you get free drives for suckin his cock. Fark off you rude prick. :nyaanyaa:
hey mate keep me out of your fantasies;
so why are you trying to get me involved in this shit, forget it now as i don,t want to have a beef with anyone ,if you have a problem with some one else pm them.
DON,T START SHIT WITH ME? :D:D
I got no truck with you dude. Love your work actually. Cant wait to see that car in action.
The other prick is just a rude bastard tho. Terry asked a civil question and deserved a civil response. Not the shit he meted out.
Good luck with your ride. :D
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
