Nissan Skyline R33 GTST
Year: 1993
Website: Carsales, Skylines Australia, Boost Cruising
Item Condition: Neck breaking head turner
Reason for Selling: New car
Price and Payment Conditions: $15000 ono $13900
Contact Details: 0405987261
This 1993 R33 GTST Skyline has been with me for 4 years, Previously with an RB3026 conversion it has since had a standard 80,000km engine and transmission conversion from a half cut.
The car is now basically standard with the whole rear K Frame end having been replaced including diff, arms, shafts, hubs and everything else associated.
The reason for this was that the whole drive line package previously in the car was sold together.
The clutch has been changed to a heavy duty sports organic and flywheel machined and a complete oil and cleaning service done on diff, engine and gearbox.
A 3" straight through exhaust with highflow cat has been fitted from the down pipe to cannon muffler.
Front mount intercooler kit and pod filter have also been fitted.
The car has been completed cosmetically with a full Nismo 400R style body kit including vented bonnet and genuine Nismo 400R plastic side skirts.
Bilstein shocks with king low springs.
A 42mm alloy radiator has also been fitted aswell as new Nismo master clutch cylinder and new slave with braided line, radiator hoses and heater core hoses aswell as new battery.
In the lighting department there is also a set of new 10000k H.I.D's.
The car has 18" 9.5" F-R Super Advan wheels with 90% tires which fill the guards the way they should and look amazing.
The car has also just been cut and polished.
Some pictures below :)
Will put up some more pics shortly.
https://www.sau.com.au/forums/topic/209731-nissan-skyline-r33-gtst-gold-coast/
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
