Well im aiming for about 230-240kws, i know i could do the conversion thing but i dun wanna ;p i like the RB20 if revs like a mofo.
i was thinking along the lines of mods:
-R34 GTR fuel pump (legend sled)
-444cc or 555cc injectors
-Cam Gears
-Cam shafts (been quoted $820 for a set of RB20 cam shafts 254 DURO and 8.5 lift) <- sound good??
-Bigger turbo, been looking at the hypergear turbos, i like the look of the TR43HF.
the cams part sound ok???
IMO I think Martin Donan from Willall Racing is one of the best tuners in the country and I know he has recently stated that a bigger turbo will always give you the biggest noticable hp increase so for a few $$$ more, I would be looking into getting that area sorted out first. Once you've got your turbo, fuel & ECU sorted out, its then a matter of choice as to what you are using the car for but cams & gears would be the obvious next bolt on to consider. My personal favourite for the street is the Tomei 'B' Poncam but rev210 who has had more hands on experience with cams on RB motors specifically may be able to further advise you in relation to choice.
Hope this helps.
im looking at almost the same...
except i have a
gt2530
gtr injectors
pfc
gtr pump..
and was wondering how the cam/cam gears are going to help.
cheers Sled. and who is this tuner? SA?
Yeah he's in Adelaide in the northern suburbs and he was involved with an R32 with Pete Hall that was the quickest in Australia 8.8sec 1/4 mile @ 160mph.
What side of town are you at cos there are 3 tuners down south that are also good.
Joel..
You can get a set of Tighe regrinds with a 254duration 8.5mm lift for $220-$300 + the std gtr sticks which can be picked up for 60-100.
rbman went with the 254's (708c grind), I believe they set him back 220ish. Simon went the 261's (805c grind) that set him back ~$300.
Don't go too big in the cams department with the rb20 as port velocity will suffer and turn it in to a lazy disappointing drive.
Myself.. 805c.
Joel..
Regrinds......cool. Who's got the masters to do them Cubes?
EDIT: der, sorry Cubes, just found them............http://www.tighecams.com.au/
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
