hey...
ok i have searched this forum for diy resprays..
is there a diy thread on start to finish..
like sanding, preping, undercoats, painting?
im looking at going satin black and i wanna give it a go myself!
any links would be good!
cheers adrian
https://www.sau.com.au/forums/topic/210104-respraying/
a compressor thats atleast 2.5hp should be fine. if the car has paint on it, use thick sand paper like 120 grade to start with, then use a 400 grade and then a 600 grade, make sure you sand with a block and not just by hand as it leave grooves, make sure to bog any dents and sand flush. wipe down the car with grease and wax remover to get rid of any oils/grease on the surface. spray primer on with a thick nozzle say a 2.1mm and do a couple of thick coats. once primmed give it a quick light sand with a 800 grade sand paper. wipe down with grease and wax again, then start you coats of paint. do the first layer light, then build up with a couple more thick layers, remember to sand with 800 grade in between coats, after the final thick coat do a sand with 2000 grade, give it a buff and you should be fine
no im not a painter by trade but have done a few cars and all have come up nice.
hope this helps you guys
https://www.sau.com.au/forums/topic/210104-respraying/#findComment-3714667
do u do a clear coat after?
now i know this is going to cause a discussion... hipe we can keep to the topic...
im going satin black...
now i know its gonna have to be straight as and thats not a problem..
now i know u still do the same procedure as u have mentioned...
but when it comes to the clear coat will i loose the satin finish or not?
cheers
https://www.sau.com.au/forums/topic/210104-respraying/#findComment-3714730
Grab some sand paper, some mates and a carton or 10 and have fun!!
Good luck, its not something I'd do to my 33 cos its too valuable to me, but maybe a bunky old daily driver, but thats me. btw, I dont actually have a bunky old daily driver, so that rules that plan out :domokun:
https://www.sau.com.au/forums/topic/210104-respraying/#findComment-3715161
buy a shitty smashed up vn conformodore and try painting it lilac for practice...
if you fuck it up then drive it off a cliff or burn it for fun
if it works sell it to some popped collar pink polo shirt weraring fucktard for 15k
https://www.sau.com.au/forums/topic/210104-respraying/#findComment-3715906
are you using 2pak or acrylic? 2pak would be the preference as the paint dries faster and has a harder finish, and as lingeringsoul said make sure you mix the right amounts of thinners, paint, hardener etc
good luck with the job mate, show us some pics when your does...remember to add that wide body kit now :thumbsup:
https://www.sau.com.au/forums/topic/210104-respraying/#findComment-3717358
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
