when i lost my license they took it destroyed it then after the months i got a new one with an X on it which means special circumstances...in my case i was only allowed 1 passenger for a year.....but as i wasnt on full license im not sure if it is the same......
  • Replies 50
did u have any trouble with the passenger restrictions rule...I;ve got it but i never handed in my license and they never said anything so i dont have that x on it..
Originally posted by pushead
man, i nearly lost my licence too.. lost all 12 points vicroad sent me 2 options either loose it for 3 months or be good behaviour for 1 year.. took the 1 year :P
Pushead, don't know how you lost so many points... the way you drive, they must have been giving points for going too slow:shake:
well i did have problems because sometimes i needed to carry more then person :D
They shouldn't destroy your license, when you hand it in they send it back out to you in the mail. i know because i got mine back on monday after 1 month suspension.
it depends on the circumstances, i had a 1 month suspension and i had to go in to vic roads and get a new license made up and a new photo taken because of the X on my license which was mentioned previously. this x stayed on mine for a year then i got another new one with no X.
