lol i thought this might be interesting duno if theres a topic about this but I have heard too many people that argue both sides for different reasons.
So what do you think? After a job well done under your bonnet, do you hold n drop ur bonnet or do you gently press it till it locks in?
get the comments goin!
https://www.sau.com.au/forums/topic/210421-drop-ur-bonnet-or-press-ur-bonnet/
Drop it!!!! but only from a few inches up. :domokun:
I've got a standard bonnet and press it down. It's stock so as long as you're not pressing it down from the middle then it should be fine.
I've heard somewhere about fiberglass bonnets cracking from pressing down?
i drop mine, coz my panel beater told me that he has seen big hand size dents on bonnets coz people press on them.
but what about the boot? :P do you guys drop it or press it?
i drop mine too...
Drop if its a GTR, my spring tension is a little high on clip, so I drop it from a little higher than most recommend, 5-7in is about right for me.
Its funny when you go to lift a non GTR bonnet, its so damn heavy in comparison you think its still locked :P
I push mine, but i make sure i have one hand either side so its not pushing down in the middle. Mines CF but so i doubt it would dent like a standard one...? Otherwise drop from a small height. Boot i have to almost slam shut otherwise it pops open.
yeh boot drops easy. i would of thought that pressing ur bonnet in the middle would be the best spot... or are you's talking about the actual centre of the bonnet. Im think where the catch lock is put ur hand on that, shouldnt bend huh. I can imagine pressing from one of the font corners, stuff that.
I wana lift up a GTR bonnet now. sounds very lite. I can do shoulder press with my bonnet. Gona open up a new gym, no weights just skyline bonnets. haha
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
