Well, we came back for another go at the skid pan after our introduction in October and I can tell you that we're definitely hooked!
Thanks again has to go to Aaron and everyone else that make the days so enjoyable. We learnt so much and had so much fun. The missus said that the 180's and 360's were the best!
I recommend that anyone who thinks they're a good driver to prove it by giving one of these days a go :thumbsup:
Anyway, I thought I'd upload some photos I took. There's heaps more so PM me if you want any more photos of your car.
Thanks,
Brett
post-25920-1205644454_thumb.jpg post-25920-1205644493_thumb.jpg post-25920-1205644510_thumb.jpg post-25920-1205644526_thumb.jpg
post-25920-1205644609_thumb.jpg post-25920-1205644628_thumb.jpg post-25920-1205644651_thumb.jpg post-25920-1205644675_thumb.jpg
post-25920-1205644687_thumb.jpg post-25920-1205644712_thumb.jpg post-25920-1205644740_thumb.jpg post-25920-1205644750_thumb.jpg
post-25920-1205644773_thumb.jpg post-25920-1205644786_thumb.jpg post-25920-1205644797_thumb.jpg post-25920-1205644818_thumb.jpg
post-25920-1205644831_thumb.jpg post-25920-1205644847_thumb.jpg post-25920-1205644860_thumb.jpg post-25920-1205644880_thumb.jpg
post-25920-1205644897_thumb.jpg post-25920-1205644919_thumb.jpg post-25920-1205644938_thumb.jpg post-25920-1205644953_thumb.jpg
post-25920-1205644972_thumb.jpg post-25920-1205644988_thumb.jpg post-25920-1205645011_thumb.jpg post-25920-1205645166_thumb.jpg
post-25920-1205645182_thumb.jpg post-25920-1205645195_thumb.jpg post-25920-1205645213_thumb.jpg post-25920-1205645223_thumb.jpg
post-25920-1205645275_thumb.jpg post-25920-1205645293_thumb.jpg post-25920-1205645319_thumb.jpg
https://www.sau.com.au/forums/topic/210600-skid-day-photos/
Daz mate.. This is the first skid pan day I've run this year!
What a quality day! Great foto's Brett. C u next time mate. I dunno about you guys, but when I got home, I was totally stuffed :( .
As u can see, there was a mix of cars.. a mix of ages and a mix of the sexes. I didn't drive as good as I could of, but with a wrapped ankle that was still swollen, I did ok! Sorry for being a bit short in the morning, the pain killers were just kicking in!
The old Val ute re-broke a control arm and the 180 would have been treated better if somebody had stolen it from the owner and his freind! I hate seeing that kind a abuse... but it was his choice to continue with the mindless thrashing. They where asked to be kinder to the poor little thing.
Anyhow, when I track down the paperwrok from Grant, I will post up the results in the Qld events section.
https://www.sau.com.au/forums/topic/210600-skid-day-photos/#findComment-3725991
Hey, I just noticed that the first photo of my car has Mark drivng..
That'll explain y all the tomatoes and bread rolls were all over the boot..!
Cant leave ur car anywhere for more than 30 secs..
Wait till i see get hold of him. lol
Hey Brett, I also noticed ur car is ALOT dirtier than everybody elses.. did u go for an off track expereince?
Edited by psi
https://www.sau.com.au/forums/topic/210600-skid-day-photos/#findComment-3726039
So everybody that wasn't at the skid day understands..
the 360's we are talking about was a fully controlled 'loose' and catch exercise which consisted of a very cool 360 spin in the middle of the pan while traveling at around 60km/h across the skid pan. We all still remained on the skid pan, and nobody had an off track adventure!
Can u do rapid shots with that camera Brett? that would be great if you could get a few shots in a row to show how it works. Send me a PM will you!
New Thread started in the Qld events section for points and stuff..
https://www.sau.com.au/forums/topic/210600-skid-day-photos/#findComment-3728808
"Burst mode" is what your looking for...
Most cameras have burst, however its useless on compact DSC's as compacts are too slow...
Entry level DSLR's can do 3.5 fps+ (frames per second) and thats what you need to show movement easily, 6fps+ is essential for high speed motorsport like drag, drift and circuit racing...
Another fun shot to take at skid pan is a "pan" or "panning" shot;
(These were done with a standard non image stabilised lens, so they are not the cleanest examples)
https://www.sau.com.au/forums/topic/210600-skid-day-photos/#findComment-3729154
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
