33 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi guys,
I'm just about getting my car tuned but still deciding between getting my stock ecu remap or get a Nistune
I have usual mods like..
- pod filter
- R34 Neo turbo
- FMIC
- 3inch turbo back exhaust
- welbro fuel pump
- single manual boost control
and i dont think i wanna do anything else to the motor at the moment.. but not sure in the future? that's why i'm consider Nistun.
Remap will cost between $400-$500 road tuned (plus dyno time if i wanna do it on the dyno)
Nistune will be $1000 drive in drive out, including everything
So, what u guys reckon? and why?
Cheers
Edited by subie
https://www.sau.com.au/forums/topic/210673-what-should-i-get-for-my-r32/
my tuner is doing nistune for $600 fitted and tuned
Nistune hardware fully installed(not tuned should not cost more that $300) + $250 an hour tuning.
Hi guys,
would u recommend me to ur tuners please??? I'm really need to get thing done asap
Thanks for all ur help guys
Cheers :)
try unigroup??? I would love to see back to back tuning of a car with a power fc and a nistune, realistically their should be minimal difference but would be nice to see if you can similar afr power figures and power curves. I am keen on getting a nistune as well, what are some other functions you can do with it?????? with the software etc?????
Wouldn't consider a PFC subie???
If your prepared to pay 1k for Nistune a modded RB25/26 PFC wouldn't cost you much more with tuning, just some food for thought :P
1K was for complete install & tune.
Good luck finding a modded Power FC for less than $1200, and then you still have tuning to worry about.
NIStune > PFC, as long as you can deal with not having the wank factor of having a hand controller.
I would love to have PFC installed in my car but.. can't find any more PCF for RB20det and the price of it is over the moon!
cheers
Read the post above yours...PFCs for other models can be made to work on a rb20...might be another option...
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
