  • Replies 54
good old clarkson,
i have one of his old videos(whats that?) where hes look for the best car in the world ever(so he says)
with richard burns(rip),and tim harvey. test ferrari,porsche,mitsi 3000gt,r33 skyline,and others
gtr eats every thing 1 second quicker fastest lap.
clarkson says fastest there but unexciting.
then says ferrai maranello(i think by memory) is best car
throught there and then clarkson has never put shit on a ferrari
must be sponsored by them or something. :)
Yeah he has given ferraris shit
I have his top 100 cars of all time at home, ok so the blue r34 GTR came in at 8th spot, now i cant remember off the top of my head but it maaaaaaay have been a yellow 355 ferrari he placed 50th because he said the front bumper and fender looked like ... the hamburglar or grimace from mc donalds??? will have to check it ouot but yeah a lot of the ferraris he did like but he did not speak to kindly of the yellow one ranked midway...
If you wanna know what clarkson thinks of Skylines maybe find a copy a copy of Jeremy Clackson Motorworld Japan. He drives a R32 GTR V-SPEC in it.
The Skyline is one of the best cars I have ever driven
Anyone notice the comments?
ell watd you expect tht he got kicked off in season 2 or 3. Cause he sucked so much. TBH the skyline had about 330hp, which is DAYUM for 2001. And no the engine was different, r34had a 2.5 litre engine, and the r33 nd r32 had 2.6 litre. Sometimes iwonder how he got chosen?
lol.
For some odd reason im lead to believe the R34 GTR had an RB26 producing 276bhp on paper? Anyone confirm this? LOL
Edited by gotRICE?
watching the old top gear episodes on you tube its pretty easy to to see how the shows increasing success has changed the content.
You will be waiting a long time to see clackson compare a 10 year old tuned car against a new model these days.
At least we can look forward to watching the new 35gtr spank some euro ass.
i cant beleive there isn't a box set yet...
There never will be.
This question was brought up with some executive for Top Gear. Apparently its because of licensing to the soundtrack. You may have noticed how many different songs they use, and their original license for using the music covers them for TV broadcasts only.
If they were to provide a DVD they'd have to negotiate a new license the music and pay out new royalties, which would apparently make the DVD not economically viable.
That's why the only Top Gear DVDs are the Challenges, since the limited number of challenges means they don't have to try and re-license too many songs.
The way I see it, a Top Gear boxed set will be like that old HRT 427. The producers think that they couldn't price it to a point where people would buy it, but the people who would buy it like it so much they'd pay a lot more. If they charged AUD$45 for each DVD, and stuck it in a nice box with some other material I reckon fans would still buy it.
the original edits will have the soundtrack in layers and they could be replaced with other music if they wanted...
not to mention they could price it preeety high and people would still buy it
True, or just remove the soundtracks completely and just have the sound of the engines.
But then it wouldn't be what they released on TV. And their arty guys chose that music to go with that filming and those cars.
haha that is from Motorworld Japan. I didn't finish the quote because who cares if his arse was sore driving it, He still mentioned it was the best car he had ever driven at the time.
[edit] Looks like they cut the end of it out as well. He says it is one of the best cars he has ever driven but one of the worse he has ever sat in or something.
Edited by Triptych
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
