hey guys just wondering what turbo u woulld u reckonmend to put in a r33 series 1 rb25 every where i seem to turn people have diffrent oppions i want to comfortably run 350 hp which places are best recommend to purchace it!! iv got all the nessary stuff to get me to the 350 just missing the turbo so if someone could point me in the right direction that would be great
thanks kizza
https://www.sau.com.au/forums/topic/211023-what-turbo-is-best/
To get 350rwhp with all supporting mods you have a fair few choices...
High Flow/Low mount = $1900
GT30/Low Mount = $1600
TD06/High Mount = $1800
I currently run TD06 with high mount + ext wastegate, which is good for 400rwhp (put out 325rwhp@1bar on low boost setting!)
try GTpumps or GCG or Hi Octane or Horsepowerinabox.
  • 1 month later...
A workmate of mine just had his tuned and came up with 290hp at the wheels. He uses a t3t4 (garrett to4e) and the only thing letting him down was the factory injectors... This was on 15psi and the turbo has plenty to give and responds and spools well. They are good for around the 400hp mark so that would be my bet.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
