***updated***
Hi,
Oran Park Raceway has the following days available for Private Practice
March 31st on North Circuit
April
1st Grand Prix Circuit
17th South Circuit
20th South Circuit
22nd Grand Prix Circuit
Must have a valid Cams Licence
Practice is $130
Gates open at 7.30am & Close 5.30pm
Practice is from 9.30am till 4.30pm
  • Replies 163
Posted Images
knowing Steve, yes :D hahaha
It would be a good run in wouldnt it if you kept everything at "safe" levels? but then again I wouldnt know shit!!! :)
Lucas pads eh?
I'll look into it!
Yeah Im gonna head out on the 20th if weathers good. Hopefully get a good SAU turn up.
I wont be pushing at as there is the EC s/s a week later
Your not seriously going to get it back and throw it straight out onto the circuit are you steve??
It will be run in first. Plenty of time to do that though
Gregs tuning it
knowing Steve, yes :( hahaha
It would be a good run in wouldnt it if you kept everything at "safe" levels? but then again I wouldnt know shit!!! :(
It will be on the old brakes though, and ill be going VERY carefully so dont expect a decent time - its all for fun
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
