Hey!
I've been having this weird issue, thats on my nerves for quite some time.
When I coast on light throttle and suddenly apply more throttle. Like WOT, I get this clunk/kick in the drivetrain.
Or if I coast on light throttle and release the throttle pedal quickly. I also get this clunk/kick.
First I can feel it. Its like some kind of play. Probably the rear subframe/differential, cause I can sense it coming from there. Also the sound is from the rear.
If I raise the rear of the car. And try to move rear wheels by hand. I can feel there is small play until the diff(Nismo 1way) engages and spins another wheel.
Something like ~1cm play. I can rotate a wheel ~1cm forward and backward without engaging anything.
Anyone had similar problem ? What should I look for.
Sydneykid advised to look into final gear/pinion gear alignment.
Before I had a s14 3.7 final gear viscous lsd I didn't have this issue.
Car is A31.
Thanks in advance!
Yep sounds like play alright. Rear sub frame bushes rooted I guess. Drivers side front, check that bush. Big job, pain in the rear. Ive done two cars for other people, now my own has gone aswell. Oh well, the joys of owning cars
Also take a look at the centre bearing on the tailshaft, it can wear (moreso the actual rubber support that holds the bearing) & replicate the noise you're describing.
have you got excess backlash in the diff? Reach under and see if you can twist your tailshaft back and forth, there could be a big clearance between your crown and pinion wheel, which is giving you the noise on and off the throttle.
I have a similar problem on gear changes and the current suspect is the driveshaft appears to have some play in it, but I'm not quite sure yet...
Hey. It seems about right.
How do I fix it ?
  • 3 weeks later...
i got the same problem atm... im thinking of replacing all the driveshafts, thats the only thing i havent replaced. im taking my car into the shop tuesday so ill know for sure whats wrong.
I wasn't talking about cornering. I'm talking about straight line stuff.
2ways don't chutter on straight line.
Also. When in 4th/5th gear. If I start to play with the throttle. around 2/3k rpm. Like on/off operation. I can make my car to jerk so violently. Its crazy.
Need more input here, guys !
Thanks!
Interested in this, I get a jerking at really low speed if I try to slip the clutch.
I have the clunk on release/apply of throttle, and on every gear change, the diff has been rebuilt but that doesn't seem to be the issue.
I *think* we found a little slack in the driveshaft, although it still needs to be confirmed.
I have this exact same problem. I've apparently got a quarter of a turn in the driveshaft before the rest wakes up and turns with it :P Makes me jerk on gear changes and any momentum change, like I'm learning to drive manual. YUCK.
  • 3 weeks later...
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
