as the tittle says my R33 is stalling at low revs when and after turning corners or coming to a corner.
i have observed that the battery light flashes when it is about to stall but thats about it. i dont think its my battery as its brand new and only the moter cuts out but when i start it again its fine. someone said it could be the alternator and the battery not charging propably, anotehr has told me ity could be the power steering over loading the moter and another said that it was the idle switch. anyone got any otehr ideas? because this is starting to become a pain.
https://www.sau.com.au/forums/topic/211467-automatic-r33-stalling/
Mate, its been 20 mins! Relax, someone will answer your question. The battery light always comes on when a car is about to stall. It has nothing todo with the battery, its just that the alternator isnt spinning fast enough, cos the revs are too low. Battery is fine, and you say that the car is starting fine, so I'd say the alternator would be fine as well. I dont think it would be the power steering, and possibly the idle switch. My mate had the same problem as this, and turns out the throttle body was open too much, letting in too much air, and stalling the engine. Might pay to have that one checked out. Otherwise try doing a diagnostic. Or convert it to manual :D
I have always been under the impression that if you can stall an auto, you're talented... :blink:
Good luck finding the problem though. Have you had a mechanic look at it?
oh its getting a conversion in the next few months lol,
the mechanic said it could be hundreds of things and that its better waiting till it shows real problems before pulling it apart to check.
Really? Did they even look at it? Sounds a bit dodgy to me! In the mean time, have you tried driving with two feet? That way you can rev the car up more before taking off ect to keep the revs up and prevent it from stalling. Or even shift manually?
My stag will stall occasionally as well. I just removed the factory BOV and put a block off plate in its place which has caused it to happen. Im thinking the ECU needs to be reset to it can learn how to deal with the air flow again but im too lazy to d/c the battery :)
I can tell you that it is your BOV.
How do i know this?? i learnt the lesson myself. you won't have the problem if you put the standard one back on.
It is called reversion.
REVERSION - Reversion occurs when some of the burned exhaust gases are pushed back into the combustion chamber and intake system during valve overlap. This is caused by exhaust manifold pressure exceeding intake pressure or by shock waves in the exhaust ports and manifolds.
  • 10 years later...
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
