Item:
1. Cusco Rear Strut Tower Bar Oval Shaft SOLD!
2. HKS Boost Gauge SOLD!
3. Apexi SAFC-II SOLD!
4. Cusco Cap SOLD!
5. HKS SSQV SOLD!
Condition:
All items are in great working condition, plug-and-play!
Price:
Cusco Rear Strut Tower Bar Oval Shaft - $180 $150 $135 $125 $110 SOLD!
HKS Boost Gauge - $60 SOLD!
Apexi SAFC-II - $250 SOLD!
Cusco Cap - $40 $30 $25 $20 SOLD!
HKS SSQV - $280 $260 $250 SOLD!
All prices are negotiable.
To Fit: (What car)
Universal items except for the Cusco rear strut bar, all parts taken out from my Series II 33 GTS-T which i sold. SAFC-II tuned for full exhaust + 0.8 bar of boost. HKS SSQV comes with adaptor.
Melbourne.
Contact:
PM.
Comments:
Postage shouldn't be a problem, buyer pays for it though. :bunny:
However, would prefer Melb pick-up!
:D:D:D:O:bunny:
Edited by blu3chip
https://www.sau.com.au/forums/topic/211574-fs-all-sold/
Just out of curiousity how does that strut brace fit the rear of a R33? I have only even seen the following type
http://cgi.ebay.com.au/Nissan-R33-GTR-GTST...1QQcmdZViewItem
which is what I have fitted on my R33. That cusco brace looks like a front brace or rear for another model.
Edited by nigelswazi
https://www.sau.com.au/forums/topic/211574-fs-all-sold/#findComment-3780561
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
