Item: R33 skyline
Website: here
Item Condition: used
Reason for Selling: not needed
Price and Payment Conditions: below
Extra Info: if theres any thing needed that isnt listed juz ask may have cheerz
Pictures: soon
Contact Details: pm here
HEAD LIGHTS $400 FOR THE PAIR
TAIL LIGTS $150 FOR THE PAIR
BONNET IN RED WITH MEGENTA FLEC $180
STEERING RACK WITH RESIVARE AND LINES $150
FRONT AND REAR KYB SHOCKS WITH PEDDERS SPINGS LIKE NEW $400
BRAKE BOOSTER AND RESIVARE $100
REAR BRAKE CALLIPORS,ROTORS $180
REAR HUB SET UP $180 PAIR
REAR SEAT $50
SIDE MIRRORZ $60 PAIR DRIVERS MISIN GLASS
2x RADIATORS WITH SROUDS $110 EACH
POWER WINDOW MOTORS $50 EACH
FRONT LEFT BLINKER SERIES 1 $50
LOADS OF PARTS INCLUDEING INTERIOR PARTS,OTHER SUSPENTION PARTS,ALL SORTS ALL PRICE ONO
https://www.sau.com.au/forums/topic/211592-r33-parts/
pix here
http://www.boostcruising.com/forums/index....entry1282082915
also decided to sell my custom hood lining and other interior bits as the red doesnt suit my green 33
$650 for hood linging and bitz cheers
https://www.sau.com.au/forums/topic/211592-r33-parts/#findComment-3749427
sorry kretch engine bay loom went with motor and box sorry
hood lining still for sale cumz wid inner roof mould things front and rear and sun viserz all cover in the sam red velour was ova $1200 to be dun make an offer
https://www.sau.com.au/forums/topic/211592-r33-parts/#findComment-3780650
  • 1 month later...
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
