I had a few mates that went and said Easternats is getting worse each year. I went last year and can safely say it aint no summer nats. It's bogun central down there and whats worse is every cop and there dog are waiting to defect you on the way out. Personaly i saw better cars in the car park than on the track .lol
Yeah, that was me! Was a tuff weekend, you missed out bro, i popped both tyres! :D
For the record, in the street drags that was my mate drving coz i got a random breath test in the line 4 the drags & i blew .017 from last nights binge! :D But i got tested again in the line for the burnout comp & it was .000! You got 2 be zero on track! :action-smiley-069:
Hope yous enjoyed the event!
were you the one who won the burnout comp, i wasnt there but my mate who went sore you do that lol i was like in shock and wanted to see it lolz
its good fun entering you can jst do willy nilly stuff. entered last year in a friends car. wish i had something to enter this year. least it keeps people off the street too bad its only 2 days now and the price is jacked up
I have been to many easternats but only entered once, gotta say its definately an entrants event more than a spectator event.
i'm so proud of this thread it's my 1st and going well.. :action-smiley-069:
LOCK IT LOCK IT LOCK IT lol
I dont think i won! No 4cyl has ever won! I didnt hang around for the prestations, but now im curious 2 see were i placed! Imagine i had a cheque in the mail! :rant:
Edited by MR-GTIR/S15
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
