Hi all
R34 GTT 2 door coupe coilovers - Aus spec Tein Super Streets
They are in excellent condition, no leaks, nothing broken, nothing is wrong with them. I still have the original Tein stickers, C-spanners, allen keys, documentation, everything!
They were bought from Wholesale Suspension in Penrith and fitted by them.
Fulcrum Suspension spec. So are valved for Australian conditions as they are advertised. RRP was $1850 when I bought them.
They still have 30000kms warranty from Wholesale and Fulcrum on these. If there is an issue, simply get it checked out and make your warranty claim. I can provide you the Fulcrum warranty certificate and receipts.
Spring rates are 5k front and 4k rear which are very decent rates, and they handle superbly. Very very predictable. They also allow a good deal of adjustment, I have my car at the momment at 345mm all around, and I am sure it can go lower another 10-15mm if needed. Else you could even run them at stock height. They have 16 damper settings.
Selling as returning car to stock.
$1000
PM me or call on
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
