hey everyone i am a third year apprentice , who works from home on the weekends doing minor services on all models and most other mechanical work on pretty much all turbo nissans having the last three years experience in nissan performance working for ...... probably best not to say but i am cheap do a stunning job and take the upmost pride and respect in all my work , i can do anything from, cheap system installs to general log book servicing to timing belts engine removals and installs and most clutches breaks etc. if you would like any more info please pm me and will get into contact ,
to the forum leaders if i am unable to advertise this way i am sorry and please delete thread thanks
https://www.sau.com.au/forums/topic/211731-cheap-mechanical-work/
  • Replies 100
i do but for the muck around you are better off to take to a diff specialist or buy a 1.5 way as it would take me too long to get all the clearances and torque settings right it wouldnt be feesable
sorry.
Hey guys,
Thought I would let you know that I contacted John after seeing this thread and ended up taking my R34 GTT to him for part of its 100,000km service. Had him do timing belt, water pump ect. He also ended up doing the accessory belts too. He was really easy to deal with, offered excellent customer service and had great prices. However he also knew what he was talking about and did a better physical job than most workshops I have been to before without any of the hassle.
I'll definitely take it back to him again in the future.
Cheers,
Tony.
Got timing belt changed, radiator flushed and bearings changed... top job car still goes fine :P
Will let you know if car explodes, but i doubt it...
Will be back soon maybe next month with more focus on swaybars and shocks with springs...
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
