Hi People's
There's something wrong with my car. At the moment what happens is that when i put my foot down it gets up to about 5 psi fine and then just seems to stay there or even drop a little when it's on standard boost which is 7psi. When i put it on high boost which is 1 bar. It gets up to about 9 pound and is then very erratic and it's go up and then down a bit some times it rev's out and fine but feels very slow and other times up the top of the rev range it stutters a fair bit. when i turn the boost off it makes about 5-6 psi but the car just does not move. It revs out but just feels very very slow. When i give it rev's and drop the clutch (rear wheel drive) as soon as it hit's boost it just stutters). i looked at the power FC and everything looks fine and the injector duty cycle seems fine i can't see any leaks. and it ramps onto boost fine. All the interior guages seem fine. I have a metal cat but my car is just a street car could it be melted???
This Problem happened last night. I had it on high boost and was flooring it when at about 6000rpm it seemed to loose power and that problem has persisted to now.
The car's modified it has:
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
R34N1 turbos C106/GT25 A/R 0.60/0.64
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
i've changed spark plugs today checked for blow bye and everything seems fine. I really need some help.
Has any one had this problem before???
Edited by black sky
coil pack?
i doubt it's a coil pack because i got split fires not long ago. and some times it rev's out fine but it's just not making the right amount of boost and it feels really sluggish.
i just don't know what to do.
done a compression test yet ? I would start here just to put your mind at ease that its not the engine itself...
do you really think it could be the engine?? it's not blowing smoke, it gets onto boost fine, and the engine's been rebuilt not long ago. Oh god please tell me it's not the engine.
it could be a lot of things...but through the process of elimination you will narrow it down to certain areas..once you are 100% that the engine itself isnt the problem then you can attack other areas...Fuel or ignition..is where its most likely at....But first be sure that engine is perfect
Hey mate check all your hoses and look for leaks in your intercooler piping BOV etc. I found I had a similar problem with the boost (not spluttering though) currently there is a leak from the gasket going into the last of the throttle bodies (to be fixed next week), worth a try. I made a very simple device from here ( http://www.vfaq.com/mods/ICtester.html ) and blew compressed air into the engine and found it. cost $7 to make and and all you need to do is take off your air box, block one of the hoses from the AFM and place this in the other. (dont need the hosing as on the website just get 65mm PVC end stop fit in nicely)
hey mate, i have the same problem i have nail polished the coil packs, gapped spark plugs but no good i can only get 7 psi to rev cleanly on boost any more than 7 and it is like the rev limiter comes on at 6000 rpm.
i am onto it, will diagnose problem soon and let u know ... :D
hi, i just put a small vid on, this is what my car sounds like to 6000 rpm, quality of vid not too good
on the street
Congrats, your a tool :blink:
EDIT: Incriminating 'hooligan' link modified...
Thx
Edited by GeeTR
i don't think it's the intercooler piping as it comes on boost as normal and i don't think it's the splitfires because every now and then even on 14psi it revs out but just feels like crap.
but i am going to try that boost leak thing, it looks interesting.
but all indications make me think that it's a blocked CAT.
  • 3 weeks later...
Ok guys here's an update
I checked the cat all is good i checked the BOV and the same problem is occuring
i disconnected the Boost controller and it's just boosting up to .7 bar and it's fine but it was alway's like that only when i put it onto high boost does it stutter. any ideas???
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
