Hello All,
My mate has a Series II R33 and he running stock boost. He has had problems with it breaking down so bad at 5000 RPM that is wouldn't rev past that point (it has only been doing this for a few weeks). I suspected buggered plugs so i go him to get a set and i when to put them in this afternoon, expecting to find one of two shagged plugs. To my surprise when i pulled the old ones out they were iridiums and they were all in really good condition with good colour. The only thing that would have been better was the gap which was around the 1mm mark.
So i started looking for other problems, when i pulled the boots off the coils packs none of them had the graphite electrode in them that i expected to see, (I have a CA18det 180sx and my coil packs have the electrode in them). I called one of my mates who has had a few skylines and he said that he would have expected the coil pack to have had this electrode.
So the Question is; "Knowing that the Series II 33's had slightly different coil packs do they still have the graphite electrode?"
The pic's;
Back three Coil Packs (they were all the same);
One of my old CA coil packs;
Anyhow i gapped the copper plugs he bought to 0.8mm and chucked them in and it does now rev out, but we could load the engine up because it's wet and it just spins up. If the coil packs are supposed to have the tab in there when he starts running some boost then i suspect he will start having spark problems again.
Edited by D_stirls
https://www.sau.com.au/forums/topic/211963-r33-gts-t-series-ii-coil-packs/
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
