hey all
im thinking about going widebody for the 32 but i think i like the mean tuff bolted look over the blended...
has anyone got any pics of rivet bolt widebody on a 32 i cant seem to find any, im pretty sure theres members on here with them....
also anyone recommend any places where i can get the wide body bits from?
thankyou in advance
https://www.sau.com.au/forums/topic/212019-widebody/
Tokage Imports down the coast can get bolt on flares for the r32.
looks f**ken hot when done the correct way as well.
+1 for cutting th guards though
and you will need some wheels with big neg offset and wide to make it look good.
http://www.tokage-racingimports.com/
https://www.sau.com.au/forums/topic/212019-widebody/#findComment-3763410
  • 3 weeks later...
think the OP's talking about rivetted on flared guard skins, not torana flares.
unless its a track car (or a track pig) it looks ghey with aids really. also its kinda pissweak if you do it on anything under a 30mm flared fender.
https://www.sau.com.au/forums/topic/212019-widebody/#findComment-3818244
Thats a bit harsh shan lol
Not a fan either just get the rears flared
https://www.sau.com.au/forums/topic/212019-widebody/#findComment-3818256
lol if my beaten up sack of shit had rivetted on guards, it'd look natural... cos it'd continue the "ghetto" theme.
but if a nice clean straight car had rivets all over it, and wasn't blended in... unless it was a track car everyone would just think you're a massive poser.
https://www.sau.com.au/forums/topic/212019-widebody/#findComment-3822172
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
