Nope made MADGTR had WEDS. I rolled the rear guards and removed one the front inter guards. The side i didnt remove the inter guard on rubs so i will have to remove the other. And i have 265/35s they look a little stretched but it adds to the look i think.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
